Purge Solenoid location
Old Nov 27, 2019 | 05:30 AM
joeyd715's Avatar
Default Purge Solenoid location
Hello, I have a 2014 Mitsubishi Mirage ES, I have a code P-0442 smal evap leak. I am looking for the Purge Solenoid. Location. I have looked everywhere, they are all are starting to look the same, not sure which one it is. I am mechanically inclined, and a DIY type of person, however never had dealt Mitsubishi. I have tried researching the Engine Schematics on google, nothing. I tried youtube same results, all they have is 2002 EGR valve location for the Mirage. I just need to know where the purge selnoid location is. Is it near the intake manifold, or anywhere in the engine area, or is it on the canister. Any help would be appreciated. If anyone has a schematic to the location of the Solenoid would be deeply appreciated if you can upload it, for viewing or download. Thanks!!!!!
Old May 4, 2021 | 11:23 AM
Don Nevill's Avatar
Hi
There's one up on the engine and one back on the canister. I have a manual if you'd like it.
Old Aug 1, 2021 | 08:41 PM
Hank007's Avatar
Hey Joeyd,
I have the same problem and also have a 2014 Mirage. Like you, I couldn't find anything online so I followed the lines from the charcoal box in the rear. The purge valve is on the engine block underneath the oxygen sensor. Remove the plastic air filter stuff on the top and you'll see it on the right under the O2 sensor. Unfortunately, it doesn't look very accessible since the battery case is right next to it. I'm going with the gas cap replacement first and hope I don't need to tackle this purge valve.
Cheers
BRD
Mar 17, 2021 02:11 PM
houm_wa
Feb 27, 2017 11:41 PM
David Temple
Oct 29, 2016 09:56 PM
admonte
Mar 28, 2013 12:31 AM
Chizad050
Apr 5, 2011 12:05 AM
