is there any mechanic here,really need your help
Old Jan 23, 2012 | 08:23 PM
Winston's Avatar
Post is there any mechanic here,really need your help
i have a Mitsubishi colt ralliart but it wont start,well they said that the ecu is working,change both crank n cam sensors,check tru the wiring for any open circuit that part is k.the problem is that current is not coming down to the plugs.each time we put the diagnosis on it said po340 n there is a new cam sensor on it,so i am really confuse,dnt know what other options leave.really need your advise plz n thanks.
Old Jan 24, 2012 | 07:51 PM
mxmikie's Avatar
bad timing belt
Old Jan 25, 2012 | 07:20 PM
Winston's Avatar
but is a brand new timing belt on it.
Old Jan 25, 2012 | 07:44 PM
dsm1990gsx's Avatar
Have you tried checking compression?
Old Jan 26, 2012 | 06:55 PM
Winston's Avatar
good compression is there.one time it start enuh but they had to crank the engine over n over till start but it didnt keep up just shut off,what they did was to take the cam sensor out of it housing n flash again a iron metal r sumting,da was how they got current n made it start.
Winston
Feb 13, 2012 11:24 AM
jeffgolem
Aug 13, 2007 05:42 PM
jessemac
Aug 3, 2007 10:55 PM
BurgRat
Aug 16, 2006 11:30 PM
Richie03
Dec 12, 2005 11:14 PM
