What could be wrong?
Old Aug 17, 2006 | 05:40 AM
importorigins's Avatar
Default What could be wrong?
Well I just changed out some spark plugs and the spark plug wires cause the car was running hard. The check engine light came on before I did the changes and is still on right now I have not had a chnce to get it reset yet. I am now having a problem with the acceleration. The car starts jerking when I accelerate and it does this between 2500 and 3000 rpms. Could it be the fuel injectors?
Old Aug 18, 2006 | 03:21 AM
Default RE: What could be wrong?
Well just figured out what the problems is. Going to replace all the fuel injectors. Upgradeing to 550cc injectors. Its putting quite a dent in my pocket but it should help the car run better. I might even replace the pump and filter as well. Just to be on the safe side. We shall see though.
Old Aug 18, 2006 | 10:09 AM
the spark plugs might not be tight?
Old Aug 18, 2006 | 01:49 PM
Checked them. turned chk engine light off and it came back as a cylinder 4 misfire a second time
tidus10
Mar 7, 2006 10:51 PM
TXSpyder
Nov 24, 2005 02:33 PM
desirableeklipse
Sep 21, 2004 03:50 PM
Ra11iartEclipse
May 21, 2004 06:29 PM
