camber prob
Old Mar 3, 2008 | 08:54 PM
4Geclipse's Avatar
Default camber prob
ok so i lowered my 06 eclipse and its been given me some problems. 1st tires are starting to wear unevenly. 2nd bought a camber kit and took it to get put onbut a machanic said if i put the kit on to adjust the camber, the wheels would stick out to far and damage the fender if i hit a bump. im lost and i dont know what to do!! should i just get an alinment? should i put it back to stock?? plaese help. THANKS
Old Mar 4, 2008 | 09:35 AM
Default RE: camber prob
what type of camber kit is this. Usaully it will just replace the stock brackets with an adjustable bolt
Old Mar 4, 2008 | 11:22 PM
4Geclipse's Avatar
well the kit is for the rear tires and it has two brackets for each side with and adjustable bolt
this is the kit i got
http://iapdirect.com/product.php?pro...t=0&page=1
Mike420
Feb 6, 2007 08:29 PM
eclipse27
Jan 26, 2006 10:51 PM
d412k5t412
Oct 10, 2005 03:06 AM
TheAdvocate
Sep 16, 2005 05:24 AM
PoconosKel
May 24, 2004 12:15 AM
