pulsing brakes
Old Sep 24, 2008 | 12:19 AM
shadowmancer's Avatar
Default pulsing brakes
here and there when i step on the brakes, i believe mostly at high speeds maybe, my brake pedal sort of pulses back and forth, up and down. not to far but enough to move my foot and for me to notice. usually ill have to hit the brakes even harder then to stop. could there be a leak or is this time for new rotors and pads? 99 eclipse
Old Sep 24, 2008 | 06:29 AM
Default RE: pulsing brakes
pads and rotors
Old Sep 24, 2008 | 06:32 AM
silvercoupe97's Avatar
Warped rotors. If you had the wheels removed for balancing or anything the requires the wheels to be removed, chances are good that the mechs used an air gun to reinstall them and tightened them down toooooooo much, which causes the rotors to warp. The pulsing pedal is usually a sure indicator of this.
Old Sep 24, 2008 | 07:19 PM
dsm1990gsx's Avatar
What they said ^^ sounds like the beginning stages or your rotors warping andmajor brake fade.
Old Sep 24, 2008 | 11:53 PM
fantastic. arite thanks for the help, ill take the wheels off and check em out. anyone have any suggested brands for slotted rotors and some pads to go along with em
Old Sep 25, 2008 | 04:32 AM
EBC greenstuff.
I'm using EBC redstuff. Good stuff.
Anyway slotted/drilled (or both) rotors need compound pads. The rotors will just eat up the softer organic types.
Old Sep 25, 2008 | 07:09 PM
whats a decent price range for something like those, rotors and/or pads
msport_2_outlander
Jan 9, 2015 07:30 AM
tidus10
May 2, 2007 11:15 AM
bronder
Jul 27, 2006 12:28 AM
TopL3SS
Jan 15, 2006 11:28 PM
miche77e
Dec 31, 2004 02:58 AM
