Squeaking Sound???
Old Feb 21, 2007 | 04:43 AM
spccortez's Avatar
Default Squeaking Sound???
I have a 2000 Eclipse GT, and im getting a squeaking noise from the front end... (When I accelerate/slow down)
Anyone out there know what this is? Somewhere in the suspension, but dont know where to start....
Thanks in advance for any help!!!!
Old Feb 22, 2007 | 07:42 AM
WPSpyderGT01's Avatar
Default RE: Squeaking Sound???
if your getting it on the front end of the passenger side... ill put my money on that its your passenger side motor mount.. the 3g passenger side motor mounts are known to give out really really quick.
Old Feb 26, 2007 | 02:59 PM
Kahuna's Avatar
if u have a cold air intake with air filter in the fender...in a lot of mitsubishis its hard to fit them because of the battery...On my lancer, the battery was pushing a side of the pipe onto an engine bolt....cutting into causing a squeeking nooise
Old Mar 3, 2007 | 08:15 AM
loud noises when you acc or brake.. or turn... on the passenger side.. will be that motor mount.. and if he has a cold air intake.. that would be located on the driver side
i had the same problems but upgrade my motor mounts to solid and flex
Old Dec 7, 2008 | 08:22 PM
r0cknry's Avatar
hey guys, i have a 2003 eclipse gts and i have the same exact problem and its really starting to annoy me. Im getting my timing belt replaced in a few weeks, about how much extra do you think it would cost to have my motor mounts replaced while they do that?
Old Dec 18, 2008 | 04:36 PM
dsm1990gsx's Avatar
Check the dates before you post.
hamilton456
Dec 22, 2011 08:20 PM
mr2masta
Apr 2, 2006 11:49 AM
RB26DETT Dream
1st Generation
Dec 5, 2005 02:28 AM
nakhshab
Jun 29, 2005 04:16 AM
nakhshab
Jun 11, 2005 03:27 PM
