3500rpm idle??????????????
My dad has a 95 gsx standard. When the engine gets hot the idle shoots up to anywhere between 2k and 3.5k rpm. Average is 280rpm. But today it got to almost 4k!!!!!! We put a new IAC motor on it and took the throttle body off and cleaned it. WTF is going on?
RE: 3500rpm idle??????????????
cleaned it with what? it sounds like something it not on tight like a VAC\boost leak does the idle flutter up and down and not stay steady?
Also adjust the BISS screw if you have to that is on the throttle body it is to adjust the idle RPMs
yamahablaster8230
08-29-2006 09:28 AM
