3500rpm idle??????????????
Old May 30, 2006 | 08:38 PM
paintballproam's Avatar
Default 3500rpm idle??????????????
My dad has a 95 gsx standard. When the engine gets hot the idle shoots up to anywhere between 2k and 3.5k rpm. Average is 280rpm. But today it got to almost 4k!!!!!! We put a new IAC motor on it and took the throttle body off and cleaned it. WTF is going on?
Old May 30, 2006 | 09:15 PM
TCossuto's Avatar
Default RE: 3500rpm idle??????????????
is there an icv on these cars?
Old May 31, 2006 | 12:18 AM
tidus10's Avatar
just tune the idle down manually..thats what i had to do with my spyder......
Old May 31, 2006 | 02:41 AM
cleaned it with what? it sounds like something it not on tight like a VAC\boost leak does the idle flutter up and down and not stay steady?
Also adjust the BISS screw if you have to that is on the throttle body it is to adjust the idle RPMs
Old May 31, 2006 | 10:31 AM
gum out throttle body cleaner. It just stays steady at 3500 or w/e
Old May 31, 2006 | 11:12 AM
if its not fluttering then its got to the the idle set screw (BISS). It is located on the left end of your intake manifold.
Old Jun 5, 2006 | 10:56 PM
it seems to be heat related, The hotter the engine is the higher the rps get. Today it got to 3800
Old Jun 6, 2006 | 07:29 PM
New record today............. 4500rpm!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!! WTF????
LeoGS
Nov 6, 2020 06:12 AM
yamahablaster8230
Aug 29, 2006 09:28 AM
DalbyBabe
Jan 12, 2004 08:08 PM
eclipse_rider
Oct 27, 2003 05:46 AM
Salazar
Oct 4, 2003 09:36 PM
