Shifter movement
Old 03-01-2007, 12:16 AM
Nubiebubie_GSX's Avatar
Default Shifter movement
Just wondering how many 2g owners have or had the shifter movement problem in there car. With my previous tranny it was solid no movement and up and down shifting was fine. With the tranny now i have the symptom mentioned in the vfaq website. Just want to see if anybody had it and tried that fix and have it work.
Old 03-01-2007, 01:04 AM
DSMTalonAWD51's Avatar
Default RE: Shifter movement
assuming your tranny is in decent condition, get some BG synchroshift tranny fluid and some of these:
http://www.roadraceengineering.com/p...y/2gebshft.jpg
thats about the best you can do
Old 03-01-2007, 01:09 AM
silvercoupe97's Avatar
^ that and bearings on the shift linkages helped mine stay solid. Not to mention, there's a lot of play with the springs..the ones that help keep your shaft centered when in neutral.
Old 03-01-2007, 10:32 AM
RCJr9186's Avatar
that's what i was going tosay silvercoupe, get some stainless steel shifter bearings. check cimotorsports.net they sell them.
Old 03-02-2007, 02:06 AM
After the B&M Short Through I put on mine, I have no problem with any shifter movement while in gear.
Solid as a rock.
Old 03-02-2007, 10:32 AM
RCJr9186's Avatar
Same here. I used to have a knock off short shifter, when i upgraded to B&M and the stainless steel bushings... that thing won't move if you want it to while in gear!
Old 03-02-2007, 08:03 PM
A friend suggested to get a short shifter also. But i really want to double check the two 36 mm nuts that hold the gears on the input shaft and make sure there tight. Because the sympton my shifter moving half an inch when i give gas and let off the gas seem like what the shifter movement fix on VFAQ.com is saying. If then no improvement then short shifter and see.
mchang40
05-07-2010 06:04 AM
tjbiker031
07-09-2007 08:08 AM
Prototype_fabs
08-15-2004 03:27 AM
Prototype_fabs
03-22-2004 01:41 AM
Quick Reply: Shifter movement
