Shifter movement
Just wondering how many 2g owners have or had the shifter movement problem in there car. With my previous tranny it was solid no movement and up and down shifting was fine. With the tranny now i have the symptom mentioned in the vfaq website. Just want to see if anybody had it and tried that fix and have it work.
assuming your tranny is in decent condition, get some BG synchroshift tranny fluid and some of these:
http://www.roadraceengineering.com/p...y/2gebshft.jpg
thats about the best you can do
^ that and bearings on the shift linkages helped mine stay solid. Not to mention, there's a lot of play with the springs..the ones that help keep your shaft centered when in neutral.
A friend suggested to get a short shifter also. But i really want to double check the two 36 mm nuts that hold the gears on the input shaft and make sure there tight. Because the sympton my shifter moving half an inch when i give gas and let off the gas seem like what the shifter movement fix on VFAQ.com is saying. If then no improvement then short shifter and see.
mchang40
May 7, 2010 06:04 AM
Espadarte
Nov 23, 2007 05:22 PM
Prototype_fabs
Mar 22, 2004 01:41 AM
