shifter movement
Old Jul 7, 2007 | 10:29 AM
tjbiker031's Avatar
Default shifter movement
ok well i know my car is 10 years old and things wear...thats life. but my shifter in gear has what i think is way to much side to side motion, is that normal is that just a 2g thing or is a bushing worn out somewhere that needs to be fixed? it doesnt effect the car in gear or anything it drives fine, its just one of those anoying things.
Old Jul 7, 2007 | 11:49 AM
50ul }{4ck3r's Avatar
Default RE: shifter movement
i wanna say the bushing...get a 2nd opion....<-----SPELL CHECK
Old Jul 7, 2007 | 03:59 PM
I Drive Naked's Avatar
I *think* this is a common problem with the dsm's involving the shift forks.
Old Jul 7, 2007 | 08:15 PM
silvercoupe97's Avatar
Mine had it too. My issue was the rubber bushing on the shift cables, on the tranny side, and the shifter's pivot point...the spring has toooooo much gap between it and the shaft that it sits on. There are kits out there that include a cylinder that slides over the shaft that the spring sits on and takes up the gap. The key is removing as much gap as possible and the worn, cracked, shrunk rubber bushings on the shifter cable..tranny end.
Old Jul 8, 2007 | 03:04 PM
tjbiker031's Avatar
yea mines doing that too, where might i find a kit to fix it?
Old Jul 8, 2007 | 07:32 PM
It's called a shift kit. EPSI has them and some others too.
Click the pic for the link and notice that long cylinder in the pic? That's what I was talking about.
If you want to make the shifter have even less movement, add on the shifter bearings..
Old Jul 9, 2007 | 08:08 AM
RCJr9186's Avatar
that's were i was going also johhn. they sell stainless steel bushings at www.cimotorsports.net
mchang40
May 7, 2010 06:04 AM
Nubiebubie_GSX
Mar 2, 2007 08:03 PM
Prototype_fabs
Aug 15, 2004 03:27 AM
Prototype_fabs
Mar 22, 2004 01:41 AM
