Internal Lounge Chat about beefing up your insides here.
Timing Tensioner Montero 3.5L help
Old 11-22-2015, 01:59 PM
dooley's Avatar
Default Timing Tensioner Montero 3.5L help
Can anybody clarify the steps when installing a new tensioner and tensioner pulley. I bought the tool with the pins. What I don't understand is the sequence of tightening goes. If the bolt through the pulley locks the pulley in place while you tension and put the belt on. What happens when you pull the grenade pin from the tensioner. Do I then back of the pulley through bolt?
Old 10-29-2016, 08:15 PM
mxmikie's Avatar
no you leave the bolt tight the tensioner with the pin takes up slack as the belt stretches with wear
n.w.m
07-16-2017 12:09 PM
Dwright152
06-19-2014 08:18 AM
TerryD
02-05-2011 07:45 AM
BillE
10-14-2008 05:07 PM
ultramindbrk
01-09-2007 02:20 PM
Quick Reply: Timing Tensioner Montero 3.5L help
