Internal Lounge Chat about beefing up your insides here.
Timing Tensioner Montero 3.5L help
Old Nov 22, 2015 | 01:59 PM
dooley's Avatar
Default Timing Tensioner Montero 3.5L help
Can anybody clarify the steps when installing a new tensioner and tensioner pulley. I bought the tool with the pins. What I don't understand is the sequence of tightening goes. If the bolt through the pulley locks the pulley in place while you tension and put the belt on. What happens when you pull the grenade pin from the tensioner. Do I then back of the pulley through bolt?
Old Oct 29, 2016 | 08:15 PM
mxmikie's Avatar
no you leave the bolt tight the tensioner with the pin takes up slack as the belt stretches with wear
ultramindbrk
Jan 26, 2025 08:47 PM
n.w.m
Jul 16, 2017 12:09 PM
Dwright152
Jun 19, 2014 08:18 AM
TerryD
Feb 5, 2011 07:45 AM
BillE
Oct 14, 2008 05:07 PM
