Mitsubishi Eclipse & Eclipse Spyder For years, the Eclipse line has stood for cutting edge styling and performance at an affordable price.
Fan will only know while in motion.
Old 01-07-2016, 05:28 PM
TJUSGS's Avatar
Default Fan will only blow while in motion.
Hello.
I don't understand this.. Maybe someone knows the solution..
I'm trying to avoid mechanics unless it's really needed.
I have a 2008 Eclipse Spyder GS. For some reason, when I'm stationary, (stoplight), my fan won't work at all.. When I begin moving, the heat will finally begin blowing out. (Not at full force.)
I can't change the variable speeds, either..
Does anyone know the solution for this? Even my local Advance store says they haven't heard of this...
Thanks.
Old 01-08-2016, 12:10 PM
Guyfromhe's Avatar
I've never heard of the stopping/going causing it but if your variable speeds aren't working you probably have a bad blower motor resistor...
Maybe something is loose?
marybethll
06-26-2021 11:32 PM
blue450yo
08-21-2008 09:20 AM
bpage020602
05-25-2007 08:01 PM
Drizzo
02-18-2006 01:31 PM
Quick Reply: Fan will only know while in motion.
