Mitsubishi Eclipse & Eclipse Spyder For years, the Eclipse line has stood for cutting edge styling and performance at an affordable price.
Fan will only know while in motion.
Old Jan 7, 2016 | 05:28 PM
TJUSGS's Avatar
Default Fan will only blow while in motion.
Hello.
I don't understand this.. Maybe someone knows the solution..
I'm trying to avoid mechanics unless it's really needed.
I have a 2008 Eclipse Spyder GS. For some reason, when I'm stationary, (stoplight), my fan won't work at all.. When I begin moving, the heat will finally begin blowing out. (Not at full force.)
I can't change the variable speeds, either..
Does anyone know the solution for this? Even my local Advance store says they haven't heard of this...
Thanks.
Old Jan 8, 2016 | 12:10 PM
Guyfromhe's Avatar
I've never heard of the stopping/going causing it but if your variable speeds aren't working you probably have a bad blower motor resistor...
Maybe something is loose?
marybethll
Jun 26, 2021 11:32 PM
blue450yo
Aug 21, 2008 09:20 AM
bpage020602
May 25, 2007 08:01 PM
Drizzo
Feb 18, 2006 01:31 PM
