alternator removal
Old 06-26-2006, 05:51 PM
alian325's Avatar
Default alternator removal
Hi everyone,
I think I need to replace alternator on my 2000 glalnt 4cyl (auto)
Does anyone know how this is done? Should prepare for a horrific day under the hood.
any advice would be helpful.
CHEERS!
Old 06-28-2006, 11:00 PM
Default RE: alternator removal
It's a pretty straight-forward procedure on some cars. For others, it can be a nightmare. Get a Haynes Repair manual and it will most likely give you a detailed procedure with pictures (although the last time I checked one of their manuals the pics were in black and white.) They will also give you torque specs, which I recommend you follow as closely as possible.
To save yourself a potential hassle, see if your alternator is properly grounded. If it's not properly grounded, your alternator won't charge. It's as simple as that sometimes!
I can't give an accurate diagnosis (nor can anyone else really) from the description. Maybe if you give us some of the symptoms we'd be better able to help you!
holyghostthug
10-15-2022 05:56 PM
mlahrens
01-29-2016 06:54 AM
4g6gShiz
02-22-2011 06:02 PM
exquizit23
10-17-2006 11:48 AM
bedjemp
05-19-2005 02:02 PM
Quick Reply: alternator removal
