alternator removal
Old Jun 26, 2006 | 05:51 PM
alian325's Avatar
Default alternator removal
Hi everyone,
I think I need to replace alternator on my 2000 glalnt 4cyl (auto)
Does anyone know how this is done? Should prepare for a horrific day under the hood.
any advice would be helpful.
CHEERS!
Old Jun 28, 2006 | 11:00 PM
Galant Kid's Avatar
Default RE: alternator removal
It's a pretty straight-forward procedure on some cars. For others, it can be a nightmare. Get a Haynes Repair manual and it will most likely give you a detailed procedure with pictures (although the last time I checked one of their manuals the pics were in black and white.) They will also give you torque specs, which I recommend you follow as closely as possible.
To save yourself a potential hassle, see if your alternator is properly grounded. If it's not properly grounded, your alternator won't charge. It's as simple as that sometimes!
I can't give an accurate diagnosis (nor can anyone else really) from the description. Maybe if you give us some of the symptoms we'd be better able to help you!
holyghostthug
Oct 15, 2022 05:56 PM
mlahrens
Jan 29, 2016 06:54 AM
4g6gShiz
Feb 22, 2011 06:02 PM
exquizit23
Oct 17, 2006 11:48 AM
bedjemp
May 19, 2005 02:02 PM
