SRS Light Stays On
Old 10-07-2009, 08:56 PM
schurmana's Avatar
Default SRS Light Stays On
Just wondering if anyone knows of a specific component or condition of the Supplemental Restraint System that will mostly likely cause this problem on an '02 Lancer. From what I've read, my only option is to take it to the dealer to have the codes read/reset. Any ideas? Thanks.
Old 10-07-2009, 09:06 PM
dsm1990gsx's Avatar
W/o knowing what code you have it could be anything.
Old 10-12-2009, 08:58 PM
schurmana's Avatar
Received a quote from the dealership today...they said $70 to diagnose the problem. I guess I'll be taking it in to see what they find.
Old 10-14-2009, 07:07 AM
schurmana's Avatar
I called another place that said they will do the diagnostics for $60. The mechanic there told me that if the horn or any other buttons on the steering wheel are not working then it's probably a bad clock spring in the steering column. The clock spring allows power to run to the components in the steering wheel, including the air bag. So far I've only checked the horn, and it works.
Old 11-05-2009, 11:11 PM
jgbrules's Avatar
why dont you just take it somewhere credible, like the dealer and get it diagnosed?? it could be anything from the clock spring, air bag, control unit ect, ect... you wont know till you take it somewhere. then you will know and wont have to speculate!!! jeezz!!
Old 11-23-2009, 05:20 PM
schurmana's Avatar
Duh, jeezz jgbrules, I thought the purpose of this forum was to get advice, thoughts and opinions from members before getting hosed at the dealer! Thanks for your opinion!
To the rest of you who'd like to know: I took it to a local garage a couple of weeks ago and they changed the clock spring. No SRS light since.
Old 11-23-2009, 08:27 PM
dsm1990gsx's Avatar
Did the mechanic ever tell you what the code was?
Old 11-28-2009, 12:10 PM
schurmana's Avatar
If I remember correctly, I think it was 92.
Old 12-01-2009, 05:41 PM
BEAT's Avatar
keep that on your records.
08 - 09 lancer got problem with front air bag sensor. I have to go the dealer this weekend to fix the recall for free.
geezcow
07-05-2014 04:03 AM
pratik91
02-09-2011 12:04 PM
debbiesz
08-04-2009 02:20 PM
pgb205
06-04-2009 10:40 PM
03outlander
09-16-2008 01:15 AM
Quick Reply: SRS Light Stays On
