engine compatibility with honda?
Old 03-13-2014, 08:12 PM
dangallagher23's Avatar
Default engine compatibility with honda?
I have a 2003 Montero Sport 3.5l engine that is bad. I called a junk yard and they told me that I could use a 2000 Honda Odyssey also a 3.5l engine. He said there might be an issue with sensors but the engine will be ok to replace. Is there a website that can show compatible engines from different vehicles? Also, has anyone had any experience using a Honda engine in a Montero Sport vehicle? Please help me.
Old 03-13-2014, 08:57 PM
mxmikie's Avatar
i think the guy you talked to is smoking crack ask him if he will install it
Old 03-13-2014, 10:40 PM
Akzle's Avatar
hahahahahahahaha.
Anything will fit. Whether you run out of money or patience first depends on your attitude. But you will run out of something. And then youll have two half cars.
Old 03-14-2014, 02:04 PM
navidbe's Avatar
dude its a f-ing honda.
there is no way possible to fit that into your car unless you do a lot of fabrication, tranny swap and even then you can even get it to work properly with the computers.
honda and acura will work for each other because they are the same company.
Old 03-15-2014, 12:05 AM
Bring me a jet engine from a commercial jet liner, and I'll make it fit.
Good idea? Nope.
Gerard
1st Generation
09-26-2010 09:39 AM
Bastun
04-16-2010 07:37 PM
jerusry
02-10-2009 11:53 AM
xxiong88
05-15-2007 05:45 PM
g_eclipse
11
05-21-2006 02:32 PM
Quick Reply: engine compatibility with honda?
