HID Conversion DONE! (Pics and info)
Old Dec 16, 2008 | 10:20 PM
  #31
dekodan's Avatar
Default RE: HID Conversion DONE! (Pics and info)
Double checked... They are D2R
Old Dec 16, 2008 | 11:35 PM
  #32
jsrd's Avatar
Perfect ! Again, great job dekodan [sm=smiley20.gif]
Old Dec 16, 2008 | 11:48 PM
  #33
tdford's Avatar
Yes the OEM HID bulbs are D2R, which are designed for reflector housings. And yes D2S are for projector housings. You can tell from the pic that the design of the bulb has a precise metalic coating on the side. This is not on D2S bulbs, so I can say with confidence that the coating helps with the cutoff for reflector housings.
and jsrd, great pic of the comparison of the HID and Halogen housings. I knew there was a difference, but I never had the chance to see them side-by-side. GREAT!
Old Dec 17, 2008 | 12:30 AM
  #34
jsrd's Avatar
ORIGINAL: tdford
...D2R, has a precise metalic coating on the side. This is not on D2S bulbs...
Thank's for your commentaries. . .
Old Dec 17, 2008 | 01:07 PM
  #35
ezekiel044's Avatar
ORIGINAL: jsrd
Thank's dekodan. One more commentary: the correct type of HID bulb for the type of optical in our Outlander (low beam) is D2R (reflector type); D2S is for optical projector type, data to consider for those want makes this modification [sm=smiley20.gif]
Forgive the ignorance but I thought our bulb were 9006? I'm about to order a HID kit but I'd like to make sure...
Thanks!
Old Dec 17, 2008 | 01:15 PM
  #36
tdford's Avatar
ORIGINAL: ezekiel044
Thanks!
We were talking about the stock OEM HID bulbs, which are D2R. If you have halogen bulbs and are doing the swap, then yes you need 9006.
Old Dec 17, 2008 | 01:21 PM
  #37
ezekiel044's Avatar
Thanks!
Old Dec 17, 2008 | 03:31 PM
  #38
AdamBNYC's Avatar
What do you guys think of these?
http://www.hidexpert.com/p9006_rebased_bulbs.html
Old Dec 17, 2008 | 04:57 PM
  #39
mitsupartsman.com's Avatar
WOW, there's alot of info on this thread......Thanks Guys and GREAT JOB on the install dekodan [sm=icon_cheers.gif]
Old Dec 17, 2008 | 11:21 PM
  #40
Melvin8078's Avatar
Where else can you buy the capacitors? I am in Edmonton, Canada. I went to Circuit city today and they had nothing.
