Light Problems
Old Mar 22, 2008 | 01:52 PM
Tmann26's Avatar
Default Light Problems
Hiyas, I recently bought some projector lights for my 3g, and last night, my low beams just stopped working. I find it odd that they'd both crap out at the same time, checked the fuses, and moved relay's around, but everything seems to be in order. Light bulbs are in great shape, any ideas where I should go fromt here?
Old Mar 22, 2008 | 04:52 PM
Tmann26's Avatar
Default RE: Light Problems
Okay, problem solved, BOTH light bulbs burned out at the same time, however, they were craked and burned-out at the base of the lights, not the main filament. Wierd, now I'm left wondering wtf, what would cause both lights to burn out at the same time? Also, after moving relay's around, my horn honks when I lock the doors, rofl. I hate electrical stuffs, it always confuses me.
Old Mar 25, 2008 | 02:12 AM
shreffdogg's Avatar
Dude I'm having kind of the same issue with my friends 2000 eclipse gs. I'll copy and paste my message thatI put in the general chat section below. If you figure anything out as to the cause, could you let me know? I thinkher lights are just standard though.
I've been chasing a head light issue on my friend's 2000 Eclipse for a little while now. When you switch on theheadlights, they do not illuminate. They do come onevery now and again for only a few seconds though and cut right back off. like one out of everyone hundred tries. The high beams workperfect all of the time though, so no issues with them. I've slaved in a new dimmer switch on the column, but it did not fix the problem. Next I slaved in a different combonation switch (the whole columnswitch and board behind the steering wheel)thinking the circuit board on the one installed was bad, still did not fix the issue. I checked the fuses and they seem fine. I've checked the relay by swaping it with the high beam and parkinglight relays stilldid not fix it.I cleaned all of the grounds I could find. I think they share a common ground with the high beams though. It seemsthat there is no power getting to the relay becausei cannot hear itclick when I turn the switch on, even during theswaping of the relays. The original relay that was in the low beam position works in both the high beam and parking lightslots, soI know the relay is fine. I'm puzzled as to why they still do seem to workonce in a blue moon though and cut right back off. Sounds like a grounding or resistance issue, but it's beating me up. Just looking to see if some one out there may be able tohelp me out with some advice.Any and all inputon this is greatly appreciated!!!
Old Jul 6, 2010 | 11:43 AM
02Lancer1971's Avatar
drivers side headlamp went out on my lancer, replaced it and it worked about 3 weeks before going out (or so I thought) it works on hi beam just not low, the bulb is not burnt out....Wiggled the wires the other day and it came on on low beam drove it and seemed to be working well, put lights on bright and then back to dim and OUT AGAIN!! Do I have a short or something, what can I do to fix it?
Old Jul 6, 2010 | 07:25 PM
Sirios-02ECLIPSE2.4's Avatar
and just a tip your horn is supposed to honk when u lock your doors.
mainelary
Jul 12, 2021 10:32 AM
jp2000
Jan 1, 2012 05:21 PM
p4c0
Feb 22, 2007 06:36 PM
GerardB
Dec 8, 2005 11:20 PM
Ooopsy67
Jun 30, 2004 10:16 AM
