2003 Mitsubishi Montero Code 35
Old Aug 5, 2009 | 01:04 PM
frogfamily5's Avatar
Unhappy 2003 Mitsubishi Montero Code 35
Hi, I received a code 35 on my montero. At first it was a code 41 that meant the O2 sensors which I have already replaced twice and my friend was able to finally clear that code but now I get a code 35. What could this mean? It has to do with the transfer case he said. What do you think? What could it be?
Thanks -Marie
Old Aug 5, 2009 | 05:11 PM
carlover626's Avatar
Do you have the complete code P0xxx? I am not aware of two digit codes...OBD-II (your onboard diagnostic system) has codes like this - P0135 - which refers to a Bank 1 O2 sensor. P0041 refers to your downstream O2 sensors.
Were the codes pulled from another componenent like the tranny?
Old Aug 6, 2009 | 09:17 PM
jgbrules's Avatar
code 35 or other 2 digit codes can be found in the ABS system. this will also give you codes for the transfer case.
njoehow246
Mar 28, 2015 06:26 AM
Misha Pirtakhia
Jan 6, 2014 07:01 PM
paparoach
Dec 22, 2013 06:14 PM
2003EclipseRS
Oct 18, 2011 02:57 PM
psychoscoot
Sep 24, 2009 07:59 PM
