What Is wrong with my car????
Old Oct 22, 2009 | 10:16 AM
imtalkintou's Avatar
Default What Is wrong with my car????
Ok, so heres my problem.
I get a check engine code that comes up every once in a while and when I get it checked at Autozone the possible causes say it could be a
vaccuum leak
wiring problem
idle air control valve
But I was wondering since it is the turbo version if it could be the intercooler piping as well. I'm not a big car guy but my brother and all his friends are and they say the pipes look corroded and need to be replaced.
When I drive I can drive fine unless I really punch it in which it sputters like a spark plug is out. I have changed the all the spark plugs and the wires.
I'm just wondering what can I do to fix this and if it is the piping or something else.
I have also cleaned the Idle air control valve hoping it would fix it but it didn't.
The car also idles low or high at times and sometimes when I shift the idle will go so low it'll either turn off completely or just for a brief second.
Any suggestions and help would be great!
I have a 98 gs-t
Old Oct 22, 2009 | 12:45 PM
sounds like a boost leak to me. You can pickup a boost leak tester pretty cheap and test your system. Do a search on here since there have been numerous threads on how to do this. But that would definetly be my guess. Alot of times its the couplings/clamps on the IC pipes. Or the POS stock BOV
Old Oct 22, 2009 | 01:13 PM
thanks, I'll check that out
Old Oct 22, 2009 | 04:00 PM
I'm w/ TE check for boost leaks, the throttle body shaft seals and fuel injector insulators are 2 very common areas for boost leaks.
Old Oct 23, 2009 | 08:43 AM
Hitmachine101's Avatar
good luck with the boost leak if its the probelm,, im still trying to chase mine down,, waiting on the dejon lower I C pipe
but look on my last post and they gave me a couple good sites to construct a boost leak tester
tim99gsx
13
Sep 22, 2008 05:32 AM
1GenNA
1st Generation
Jun 21, 2008 07:21 AM
hellnoitsalex
1st Generation
Sep 9, 2007 09:29 PM
RCJr9186
Apr 23, 2007 01:28 AM
