transmission problems
Old Nov 10, 2009 | 04:24 PM
brpiach's Avatar
Default transmission problems
ok i bought a 1994 3000gt and i have had it for almost 2 years now and it has been basically a lawn ornament because it just randomly stopped working one morning i took it out for a drive and it started to kick back and then catch up with itself and once i got it home i cut the engine and let it sit for a little while then i went outside to turn it back on and it started right up, but when i put it in gear i pushed the gas and it didn't move an inch neither in drive or revers it wont move and inch it just revs up and then nothing i figured it was a problem with my transmission but i haven't been able to figure out exactly what the problem was with the transmission so can anyone offer any advice?
Old Nov 11, 2009 | 10:11 AM
Girly VR4's Avatar
automatic or manual? turbo or non turbo? and if you don't mind my asking, where are you located?
Old Nov 14, 2009 | 04:14 PM
brpiach's Avatar
well its an automatic, non-turbo, and i am located in Michigan
Old Nov 14, 2009 | 04:21 PM
Did you check the trans fluid level and condition? If it has no foreward or reverse gears sounds like it has a pump issue.
Old Nov 14, 2009 | 05:26 PM
Girly VR4's Avatar
yea, definitely check the fluid level. drain it and put fresh fluid in it also. If that doesn't fix the problem, then you're better off getting a replacement used transmission. a rebuild on those is more expensive then it's worth.
Old Nov 16, 2009 | 12:10 PM
brpiach's Avatar
now that is what i was saying i figured that the tranny fluid was burnt because it had sort of a brownish tint to it but no one else saw it and every licensed mechanic i ask would all say i need a new transmission but i just put a new engine in and i cant afford to drop another 2000 into this car right away but i guess ill just drain it and put a new filter in and see if that doesn't fix the problem and if not then ill take a look at the pump so thanks for the input but i know never buy rebuilt because they usually never last the first year im just crossing my fingers that i don't need a new one
Old Nov 16, 2009 | 05:07 PM
If the fluid is burnt dont waste your money on new fluid and filter.
Old Dec 6, 2009 | 05:52 PM
LoraHup's Avatar
Hi GeorgeI got some problems with my left foot.when i play around 120-140bpmmy left foot start to jump up and down and i cant control it.do you know what the problem can be and do you have any good exercises for it?sorry for my bad english.Thanks
jp2000
Jan 1, 2012 05:21 PM
94 Mitsu Eclipse
Dec 20, 2010 06:59 PM
kandy eclipse
Dec 16, 2005 06:58 PM
bfunk
Aug 1, 2005 05:21 PM
99eclipse
Dec 2, 2004 04:11 AM
