Did I let the belt slip ?
Old Nov 15, 2009 | 09:33 AM
pepper's Avatar
Default Did I let the belt slip ?
Hey guys I sure hope someone can help me out here, I will try 2 keep it short. I replaced the headgasket on my 93 eclipse 1.8 , I tied the belt to the sprocket befor removeing it from cam and tried not 2 let it drop down any. I did turn the crank a very little bit mabe a half inch and when I get it all back togather it wont start only hit . and also it wants 2 keep cranking over after i let off the key,with key all the way off then it will finley stop? this is the first time this has happend. I got # 1 up 2 TDC with both vales closed on that clinder stuck dist. in with roter pointing down made that #1 wire , wired clockwise 1342 . no run. need help pLEASE.
Old Nov 15, 2009 | 10:11 AM
Sounds like the timing belt isn't timed right? Also check the basics fuel, compression and spark.
Old Nov 15, 2009 | 11:55 AM
pepper's Avatar
Yes, I think you are right but are their any marks or dots on the block 2 line the cogs up 2? I have never done this type befor, and thanks for the reply.
Old Nov 15, 2009 | 12:15 PM
Hope this helps.
Old Nov 19, 2009 | 11:55 AM
pepper's Avatar
Hope this helps.
Yes, this did help very much dsm1990gsx and i thank you much , After i found the marks on the block and lined them up it started on the first round. runs great, & that $16 junkyard piston & rings worked great as well but i did knock the glaze out of the clinder wall & also went around the rings with fine emery cloth to deglase aswell . So no smoke , no knocks, all good so thanks again and if i ever need anything elce i know who 2 call on. sam.
Old Nov 19, 2009 | 12:32 PM
Glad to help.
Old Nov 19, 2009 | 12:38 PM
Glad we could help!
Mitsued
Mar 23, 2012 09:50 PM
X Treme
Jul 19, 2007 03:08 PM
matthew_m75
Mar 21, 2007 05:22 PM
racerx55
1st Generation
Feb 17, 2007 04:18 AM
madmat
May 21, 2004 01:45 AM
