94 LS radio removal
Old Jun 25, 2005 | 06:40 PM
Billiard's Avatar
Default 94 LS radio removal
how do i remove the radio on my 94 LS?
Old Jun 28, 2005 | 10:10 PM
Billiard's Avatar
Default RE: 94 LS radio removal
anyone out there have any info on removing it ive look at it and cant seem to tell....I assume the woodgrain comes off but i dont know how to get that off even...I know my stuff about cars I went to school for automechanics and i hope to land a career in the field
Old Jul 4, 2005 | 11:05 PM
pc's Avatar
pc
Trim is always a pain. The engineers always find a way to interlock it so you need a puzzle solver to remove it. From my experiance there are either clips that will release if you pry them and/or a couple of screws as well. Don't use a screwdriver as they tend to mark the plastic because they are too narrow. Use a putty knife or something wide and thin. The radio might need a pin that you insert on either side to release clips that hold it in place, or it could just be screwed in. My Ford has two clips on either side. I use a bent piece of coat hanger to insert, bend, and remove.
Old Jul 23, 2005 | 07:18 PM
LRuff98163's Avatar
Hello Billard
(1.) Remove center console. Two screw each side (front & back) and two under the ash tray. unscrew the light bulb under ashtray. remove center console.
(2.) Remove simulated wood trim over radio. two screws at bottom. Detach two electrical connections to cigerette lighter and unscrew cig light bulb. Top is held in with two clips each side. lift from bottom and pull out from top
and here's some photos to help
http://www.diamanteowners.com/compon...60545/catid,3/
TG
Old Oct 23, 2005 | 07:51 PM
gnr_70's Avatar
ORIGINAL: LRuff98163
Hello Billard
TG
TG, will this radio removal cause any problem to the engine being started? (Antitheft issues)...I can't find the CD/RADIO antitheft code card the vehicle came with. My 94 LS has the original radio/cd unit in it and the CD player is going bonkers, I put one cd in it and it does not want to eject anymore, the radio display (radio still works) is also fading out and I just want to replace the whole unit. Also what unit is a direct replacement for it? I'd like to just plug and play the new unit. I don't want to cut and solder and rewire anything. Thanks much!
mlahrens
Jan 29, 2016 06:54 AM
Maint4man
May 22, 2008 10:47 AM
benchman
Jan 13, 2008 11:09 PM
zay3254
Nov 27, 2007 09:28 PM
FOX
Apr 18, 2007 09:09 PM
