3-cylinder
Old Dec 9, 2005 | 04:30 PM
  #21
Sanguinius's Avatar
Default RE: 3-cylinder
'93.... They didn't have the 420A's then did they?
Old Dec 9, 2005 | 06:17 PM
  #22
eclipsed4u's Avatar
ORIGINAL: Sanguinius
nope...but looking at his member name...i am going to assume that he has a '93 GSX.
Old Dec 9, 2005 | 10:24 PM
  #23
Sanguinius's Avatar
God I'm slackin good call I bet he DOES have a GSX lol
Old Dec 10, 2005 | 01:03 AM
  #24
93eclipsegsx's Avatar
yes i do have a 93 gsx. . so i pulled the head off today and it is indeed an exhaust valve. a piece cracked off and i cant find it. could it affect the turbo?? or would it just go right out the exhaust and be gone? what could cause the valve to crack? to much pressure or was it bad in the first place? if you guys want to see a pic of it let me know.
Old Dec 10, 2005 | 01:38 AM
  #25
Sanguinius's Avatar
There are plenty of things that could cause the valve to crack and chip. The timeing may have been off a tooth, weaknesses in the metal, something getting into the cylinder and hitting that valve before exiting. Who knows. Before you go putting everything back together make sure to get the head warp, crack, and compression tested, as well as getting the block checked for warping on the head gaskete surface. Sounds like you MIGHT have lucked out but check the turbo and exhaust piping thoroughly for that valve piece. If it DID exit through the turbo it could be problems as it MAY have damaged fins. if it made it through it could also cause damage to the cat. Go through things with a fine tooth comb.
Old Dec 10, 2005 | 12:39 PM
  #26
it wouldnt have have done anything to the cat because i dont have one. and i still pass emissions,. i hope its not the turbo because ive only had it for about three days before this happened. we checked the timing and it looked good, the notches lined up right.
Daithi
May 29, 2005 06:09 PM
cptkid570
Feb 4, 2005 07:24 AM
PimpininEclipse247
Jan 31, 2005 03:23 AM
raidercte
May 11, 2004 03:07 PM
ForceFed4
Apr 23, 2004 12:31 AM
