94 Eclipse ... Major problem
Old Feb 10, 2006 | 03:26 PM
Silvertooth's Avatar
Default RE: 94 Eclipse ... Major problem
I asked my uncle and he said he didn't want to give advice without actually seeing the car and the problem. Otherwise he could give you some wrong information. Sorry man.
Old Feb 10, 2006 | 03:37 PM
Sanguinius's Avatar
All right have the crank and cam position sensors as well as the housings for both checked. It MAY be a cracked housing for one of those that's causing the problems.
Old Feb 11, 2006 | 04:23 AM
PooT_Nation's Avatar
.....That's weird. I've never heard about that before.
I'm thinking a govener problem? Or maybe some computer problem. Car may be thinking it's not allowed to go over 2rpm? ::shrugs::
That's really confusing problem
Good Luck man
Old Feb 11, 2006 | 05:46 AM
brandoN^gsT's Avatar
When reading your post, the first thing that came to mind was that maybe an air hose was disconnected somewhere. Reason being, when I disconnected an air hose on my car a couple of weeks back, I woul dhave the same problem. I'd pull off the line, and the car would let me rev up to about 2K RPM's, and then it would bring itself back down. I'd push it to the line, shift, and try to get higher in the next gear, but it did the same thing. Just a though...Check your hoses. Look for leaks, or disconnected hoses :/
-brandoN^-
Old Feb 11, 2006 | 09:11 AM
player69x's Avatar
my rs is kinda giving me the same problem now . the dealship reprogrammed my comp and ever since that day my car wont go over 60 mph. off the line it drives fine but 40 and up it doesnt want to move even when its being flored. check your comp like the others said.
Old Feb 11, 2006 | 06:19 PM
jhah17's Avatar
Seems to me that I get that answer from a lot of people so I will check. I was also told that I might have fried the computer when my alternator went out and I got jumped. Anybody heard of that? I mean it sounds logical that the computer isn't working for whatever reason but that seems odd that that might do it[sm=dontgetit.gif] Would it harm the computer just a little to where it would just confuse the part that controls the fuel or air? I guess it is just a little overwhelming since so many have looked it over or heard the problem but nobody has ever actually heard of it before. We'll see I guess.
Thanx,
Josh
Old Mar 2, 2006 | 03:29 AM
My93EclipseGS's Avatar
When was the last time you replaced the fuel filter? Try that first its cheap. I have also heard of problems with the ECU for the 1G cars. There is a rev/speed limiter in the ECU that has a tendency to have leaky capacitors. These caps leak onto other parts of the ECU causing all sorts of problems. This would not set off the CEL. The CEL only turns on when certain sensors are bad.
Old Mar 7, 2006 | 12:32 AM
mutman311's Avatar
I had the same problem with my 1.8. Take the ECU out and open it, There will problably be a tiny burn spot on it. I had to jump my car off a couple of times in a row and it did the same thing. Best bet find a REBUILT computer, capacitors and all only last about 7 years, so get a recent rebuild.
bstarski
Mar 7, 2013 01:12 AM
MontySport2000
May 2, 2011 03:47 AM
kka916
Mar 2, 2011 10:20 PM
TheEclipseGuy
4th Generation
Feb 2, 2008 10:06 AM
edgeofsane
Jul 20, 2006 11:17 PM
