gauge lights
Old Feb 19, 2006 | 11:20 PM
93eclipsegsx's Avatar
Default gauge lights
ok, i started my car tonight and when i turned on the lights, i now cant see how fast im going or anything else because the lights arnt working. anybody have this happen to them?
Old Feb 19, 2006 | 11:32 PM
Default RE: gauge lights
what electronics have you installed or touched recently? I going to bet you have a popped fuse, I have popped them a trillion times and the entire interior was out even the radio wouldnt work..... so check the fuses in the engine bay and the interior fuse pannels if you havent already
Old Feb 20, 2006 | 12:49 AM
Gsteclipse22's Avatar
Hey I actually had a similar thing happen to me when I worked on my gauges. Aside from the fuses I would check the bulbs in the cluster. I had loosened a bulb in the back by accident and I couldn't see anything either. Hope that helps.
Old Mar 1, 2006 | 01:12 PM
nukn_futs_demit's Avatar
ive had the same thing happen to me on my 95 rs and ive checked all my fuses and replaced all my bulb can some one tell me wat else it might be b/c my next thing to do is buy the circuit board thats on the back of the gauges
Old Mar 1, 2006 | 01:21 PM
mysterio2099's Avatar
I had this problem in my '91 Chevy Lumina and it wasn't a fuse, a circuit board, or a bulb... there was a short in the wires running from the board back to where ever it was it was running. I eneded up just beating the dash while I was driving to get the lights to work ... lol, worked sometimes
Old Mar 1, 2006 | 08:52 PM
thanks guys, it was a fuse. looked under the stearing wheel and dound nothing, so i went under the hood and replace the one there and it works great now, just cant adjust the brightneww o it anymore. dont know why.
Old Mar 1, 2006 | 09:35 PM
domestickilla's Avatar
sounds like you fryed the dimer switch somehow. so something else is causen the prob in order for t nlow your fuse. might wanna check all your electrical before replacent the switch cause they are about 45 bucks
Old Mar 1, 2006 | 10:37 PM
ill do that. and all of that happened in 1 shot because they worked about 3 hours before then because i was at a friends.
burnmyeyes
Jan 2, 2008 09:04 PM
nukn_futs_demit
Mar 19, 2006 03:38 AM
Gsteclipse22
Mar 6, 2006 03:30 AM
m3kgt_99
Jan 3, 2005 04:29 PM
