need help (not my car this time)
Old Apr 4, 2007 | 04:28 AM
natewesselink's Avatar
Default need help (not my car this time)
ok my brothers car is building extremely excessive preasure in the radiator and it built up really fast (im talking within about a city block) the pressure was enough to blow the cap out of his hand and coat the entire front of the car in coolant where thinking its a blown head gasket
would that cause the temp gauge to spike over the top mark and cause that amount of pressure build up in that short amount of time
as usual any help is appreciated
Old Apr 4, 2007 | 09:22 AM
Default RE: need help (not my car this time)
most definetly a head gasket. Do you have any smoke comming from the exhuast? Best way to check for a bad head gasket is to do a compression test. If you come back with two consecutive bad cylinders, or at least just one bad cylinder, then i would suspect head gasket. Another possible thing would be a blockage somewhere in the lines. You could try doing a coolant flush
Old Apr 17, 2007 | 09:22 PM
thanks for the advice we figured it out and he just put the radiator hoses on the wrong way its runnin just fine now
Old Apr 17, 2007 | 09:26 PM
haha, wow i wouldnt have thought of that one. Sometimes the simplest solution is the correct one i guess
Old Apr 18, 2007 | 06:57 AM
racerx55's Avatar
how the hell do you put radiator hoses on wrong
Old Apr 18, 2007 | 09:31 AM
i know im trying to figure that one out too. Didnt know it could actually be backwards
Old Apr 19, 2007 | 07:03 AM
well its a honda and this is the only car forum im a member of and i guess it goes from top of the radiatorto bottom of enginenot bottomofradiator to bottom of engine
i dont even know how it works but thanks for all the help
p.s. we checked the rediator gasses for exaust and there wasnt any so there isnt a blown head gasket
Old Apr 19, 2007 | 08:02 AM
racerx55's Avatar
HONDA explains it all, lol
Old Apr 19, 2007 | 10:34 AM
Dusty Eclipse's Avatar
ORIGINAL: racerx55
LMFAO
trailer trash
Apr 21, 2009 10:37 PM
kenlrw39
Oct 5, 2007 12:49 PM
spyder4g63t
13
Aug 6, 2007 02:03 PM
bigjay7155
Feb 18, 2006 03:28 AM
Xavsbud
Nov 9, 2005 05:15 PM
