O2 Sensor.
Old Dec 16, 2007 | 07:04 PM
nlod's Avatar
Default O2 Sensor.
1990 Eclipse GSX, I'm having issues finding the O2 sensor for the exaust. Someone told me that it was on the downpipe but I can't seem to find it to replace it. Anyone have any idea where I should look.
Old Dec 16, 2007 | 08:21 PM
dsm1990gsx's Avatar
Default RE: O2 Sensor.
Its on the o2 housing, hense o2 housing lol. Its right below the turbo, drivers side.
Old Dec 16, 2007 | 09:12 PM
nlod's Avatar
I have replaced that O2 Sensor already but someone told me there was another one on the down pipe. I know they are suppose to have 2 O2 sensors.
The problem being is I will be driving and the engine will start bogging.
So I have replaced the one you mentioned and still need to replace the 2nd one.
Old Dec 17, 2007 | 05:46 AM
how do you know its the o2 sensor. It could have something to do with a boost leak, or a ignition issue. But the second one should be on the exhaust after the cat.
Old Dec 17, 2007 | 06:43 PM
93eclipsegsx's Avatar
its a 90 so there is only 1 o2 sensor, when your driving, does it bog at a certain rpm level.
Old Dec 18, 2007 | 01:17 PM
dsm1990gsx's Avatar
ORIGINAL: 93eclipsegsx
Yeah there is only one o2 sensorup to 1995. 1996 ad up has two o2 sensors.
Is it a misfire, does it do it under a heavy load? Like everyone else said check for boost leaks.
Old Dec 18, 2007 | 01:31 PM
nlod's Avatar
Thanks guys, Once I get home I will check it out and let you know what happens.
Old Dec 18, 2007 | 07:12 PM
ORIGINAL: dsm1990gsx
actually thats nottrue. I had a 95 and it had 2 o2 sensors on it. Im guessing maybe it started in 93. Not sure, just a guess. Im sure woody probably knows exactly when but eh 95's definetly had two
Old Dec 18, 2007 | 09:16 PM
dsm1990gsx's Avatar
ORIGINAL: TheEngineer
That might be true, I thoughtsince 1995 was still ob1 and only used 1 o2 sensor.
Old Dec 19, 2007 | 01:19 PM
nlod's Avatar
Well last night I crused by the all night Auto Zone and got the stuff to make a test kit for the boost leak. So hopefully tonight I will beable to figure out exactly what the problem is. Stupid Epoxy sets so slow ><
puwit321
Sep 30, 2014 12:10 PM
Rlopez89
Jul 16, 2013 05:21 PM
batman47
Dec 4, 2011 04:21 PM
sickend
Sep 12, 2006 06:25 AM
5Tizzle
Aug 14, 2006 12:07 AM
