oil filter bracket
When doing the 7 bolt to 6 bolt conversion the oil filter bracket or pipe does not have the oil pressure guage sending unit on it or a spot to mount one. All it has is the idiot light sender.
Questions;
Does any one make a conversion kit as the 7 bolt oil filter bracket (pipe) will not fit on the 6 bolt?
Can you use a turbo version with the oil cooler blocked off?
If you use the stock 6 bolt without the pressure sensor will the computer allow the engine to run?
Where does an aftermarket oil pressure gauge mount it's sensor?
Thanks!!!!!!
Questions;
Thanks!!!!!!
lancer0594
Feb 5, 2009 06:48 AM
