oil filter bracket
Old Mar 13, 2008 | 05:41 PM
BLAZE GS's Avatar
Default oil filter bracket
When doing the 7 bolt to 6 bolt conversion the oil filter bracket or pipe does not have the oil pressure guage sending unit on it or a spot to mount one. All it has is the idiot light sender.
Questions;
Does any one make a conversion kit as the 7 bolt oil filter bracket (pipe) will not fit on the 6 bolt?
Can you use a turbo version with the oil cooler blocked off?
If you use the stock 6 bolt without the pressure sensor will the computer allow the engine to run?
Where does an aftermarket oil pressure gauge mount it's sensor?
Thanks!!!!!!
Old Mar 13, 2008 | 06:01 PM
BLAZE GS's Avatar
Default RE: oil filter bracket
Old Mar 13, 2008 | 06:05 PM
BLAZE GS's Avatar
the dark one is off a 7 bolt and the light is from a 6 there very diffent. the 7 bolt has a pessure sender the six doesnt...also they mount way diffent...
please *help*
lancer0594
Feb 5, 2009 06:48 AM
99clipsgst
Dec 19, 2008 02:22 PM
BLAZE GS
Mar 14, 2008 06:50 AM
eclipse99
Feb 21, 2006 06:51 PM
vinceaton
Jun 18, 2005 10:23 PM
