timing belt help
Old Mar 31, 2006 | 10:46 PM
BrunoBoy650's Avatar
Default timing belt help
ok well i jsut found out it wont start because of the timing belt, the shop keeps putting it back together, and it works, just for a little while, then it stops running. well they put in a new belt, new tensioner, and they keep telling me it keeps jumping. why does it keep coming loose?
Old Mar 31, 2006 | 11:48 PM
Default RE: timing belt help
someone is not doing their job right. They must just not be tightening the tensioner or something. There is no reason for this. How are the teeth on the belt. Have they been wore or something that makes them slip maybe.
Old Mar 31, 2006 | 11:54 PM
brand new belts, its happened four times
Old Mar 31, 2006 | 11:56 PM
thats f'd up. The only thing that would cuz it to slip as i understand it is the tensioner. So if that is new also, then i can only think they are doin something
Old Apr 1, 2006 | 12:48 AM
ORIGINAL: TheEngineer
ok thanks
Old Apr 1, 2006 | 01:10 AM
Joel_CA's Avatar
They may not be setting the tension properly- the timing belt is pretensioned by an offset pulley with the use of a special tool- the pretension is then maintained by a hydraulic tensioner. If the pretension is not set properly- the hydraulic tensioner may not be able to hold tension. Take is to someone more capable before they destroy your engine.
Joel, CA
Old Apr 1, 2006 | 12:33 PM
93eclipsegsx's Avatar
how much is the car jumping because when it jumped on my car it bent most of the valves. you must be lucky
Old Apr 1, 2006 | 01:47 PM
What mods do you have?
Old Apr 1, 2006 | 09:51 PM
ORIGINAL: 93eclipsegsx
idk, it bent three valves so far.
and for mods, i have a straight pipe, evoIII exhaust Manifold, MBC, Turbo Timer, HKS Intake and thats all for now
judien
Mar 9, 2018 03:41 PM
8000RPMS
Aug 30, 2007 05:49 AM
bcolins
Jul 5, 2007 07:35 PM
3000vr4conquesttsi
Jul 28, 2005 12:40 AM
xxxzgothiczxxx
Jun 29, 2004 03:17 PM
