16G Turbo Question
Old Apr 24, 2006 | 06:06 PM
whitestang5075's Avatar
Default RE: 16G Turbo Question
yea I just got done puttin mine in... It was a lil difficult but managable... It runs strong, but Im pretty sure its running way rich, I think my o2 is gone.. I got a evo3 16g turbo 2.5 " exhaust, 190lph walbro pump. hit me up if u need help
Old Apr 24, 2006 | 06:53 PM
PooT_Nation's Avatar
That's sweet to hear, Would my SMIC be supportive enough?
Old Apr 24, 2006 | 08:55 PM
dreamz's Avatar
ORIGINAL: DSMTalonAWD51
im sure you will be around that, i was able to run a 13.5 at the track with that setup, but i had al supporting mods, 3" exh from turbo back, front mount, act 2600 clutch etc, but 16g's make some good power even at 13psi it was faster than my stock turbo ever was at ~17psi
um.one question (newbeeish) how is stock turbo running at 17 psi slower than 16 g running at 13 psi ?
Old Apr 25, 2006 | 12:44 AM
DSMTalonAWD51's Avatar
ORIGINAL: dreamz
16g is a bigger turbo and flows more air. think about blowing through a coffee stirrer and blowing through a larger straw equally as hard. the coffee stirrer (stock turbo) is going to have more pressure(like running higher boost), but still flows less air because it is smaller. even though you may not be pressurizing the larger straw as much, it still flows more air, and more air m,eans more power. i suck at analagies but maybe it makes sense to some people out there
Old Apr 25, 2006 | 12:46 AM
ORIGINAL: PooT_Nation
hard to say, where do you live. id say in colder climates and on lower boost it will be fine up until a point. if you live in cali or texas etc, and/or plan on running 17+psi, get the front mount asap. im sure you have noticed how much quicker you car is at night than day, its because the tiny stock ic cant cool the air well during the day efficiently
Old Apr 25, 2006 | 01:42 AM
true dat.
like i said in the other post, my car ran better after i removed that plastic inner wheel liner. I live in So Cal, and yes, I definentally want a FMIC.
If i got a Front Mount before the 16G would it be compatible to both or would i have to change piping?
richieboy89
Dec 12, 2012 09:08 AM
get435
Mar 17, 2011 04:33 PM
itsme71190
Sep 27, 2008 06:26 PM
TheAdvocate
Feb 28, 2006 09:13 PM
Emartoo
May 10, 2005 06:12 AM
