6 bolt vs 7 bolt?
Old Sep 12, 2007 | 11:38 PM
ibbster's Avatar
Default 6 bolt vs 7 bolt?
Can any one tell me the diffrence between the 6 bolt turbo engine and the7 bolt turbo engine? i know it a stupid question but i don't know much about eclipses yet?
Old Sep 12, 2007 | 11:40 PM
Default RE: 6 bolt vs 7 bolt?
You really need to use the search fuction. Google will return so many things on this.
Old Sep 13, 2007 | 12:33 AM
50ul }{4ck3r's Avatar
dam..this crap search is alil button that is useful for newbs
Old Sep 13, 2007 | 06:41 AM
well if you know enough that there are two different ones i figured youd know the difference but whatever. The reason for the names is the # of bolts on the flywheel cuz thats one of the only ways to tell them apart. But the real difference is in the oil feed and the squirters. The 6 bolts have larger openings in the squirters and the 7 bolts take oil from if i remember the bottom of the pan which gets dirtier oil. so it ends up clogging the squirters and creates a oil pressure issue. Also the 7 bolt had weaker bearing. But im not gonna go any further. If you want more info then go to magnus motorsports and look at their write-up on crankwalk
Old Sep 24, 2007 | 07:44 PM
TSG59_Steve's Avatar
ORIGINAL: TheEngineer
Both the 6 bolt and 7 bolt take the oil from the same place, and it goes through the oil filter.
6 bolts were in most* of the 1st gen Eclipses/Talons/Lasers, the 7 bolts were in some 1st gens, and all 2g turbos.
6 bolt motors are a little more reliable.
Old Sep 24, 2007 | 07:47 PM
Dusty Eclipse's Avatar
A little more is an understatement
Old Sep 24, 2007 | 07:51 PM
ORIGINAL: Dusty Eclipse
Eh... maybe.
GermanEclipse
Dec 6, 2006 11:12 PM
red93gs
Nov 30, 2006 02:56 AM
bud660r
Aug 31, 2006 07:41 PM
petro4411
Dec 5, 2005 01:42 PM
antomx
Sep 29, 2004 02:32 PM
