96 rs clutch Q
Old Sep 20, 2004 | 04:09 PM
ryans96rs's Avatar
Default 96 rs clutch Q
Ive got a 96 rs with the 420A motor. Im replacing the clutch in it, and i thought id go with an aftermarket setup to add longevity to the clutch life. Everything went smoothly with the uninstallation until i pulled the clutch/pressure plate assembly out and found that the pressure plate is rivetted to wut the manual calls the "Driven Plate" which bolts into the flywheel. My ACT street disc and pressure plate wont bolt straight up in there cause i have to use that drive plate. Im lookin for anyone who knows how to get around this problem whether it be drilling the rivettes out and bolting the pressure plate back onto the drive plate, or buying a preassembled system that will directly replace the stock unit. Im really wanting to stick with the aftermarket route however. Any advice or info will be helpful. Thanks.
Old Sep 22, 2004 | 12:49 PM
SpyderGS's Avatar
Default RE: 96 rs clutch Q
My goodness, that certainly is a weird situation. But i do have the answer for you. Or actually Sport Compact Car Magazine has the answer for you. I have an issue that shows the installation of the clutch and pressure plate on a 96 neon(same engine/tranny). They commented on the clutch/pressure plate combo and showed a way around it. Either tommorow or tonight i will post their solution to the problem. Hope you're still here.
97spydergs
Oct 29, 2007 02:14 PM
95EclipseGS95
Aug 20, 2007 01:03 PM
bud660r
Dec 23, 2006 07:30 PM
wicked2407
Oct 25, 2006 06:07 PM
gsx man
Mar 22, 2005 03:07 AM
