'98 Eclipse wont stay running?
Old Mar 7, 2010 | 05:14 PM
hotrodt's Avatar
Default '98 Eclipse wont stay running?
So there is alot to go over with this car but I will start with the basics and go from there. 1998 Eclipse 2.0 Slow Boy Racing turbo motor, stock turbo. Car will start and run for aproximately 5 sec. and promptly shut off. If you hit the key just before it shuts off it will run for another five seconds and so on. I don't even know where to start lookin on this thing, it's different than any car I have worked on before. I am a competent mechanic but I have always worked on Mustangs and nitrous cars so this is different animal. Any help is greatly appreciated on this thing. Thanks
Old Mar 7, 2010 | 05:50 PM
dsm1990gsx's Avatar
Check simple things like a vacuum leak/boost leak. Also inspect the isc, they good bad all the time.
Old Mar 7, 2010 | 06:10 PM
hotrodt's Avatar
isc = idle speed control ?
Old Mar 11, 2010 | 06:00 PM
2slow's Avatar
i would have called it an iac he might have understood that idle air control/ if had mods such as front mount intercooler check for vac leaks that sounds more like whats happening but if not maybe a relay but its hard to diagnose over the internet
Old Mar 12, 2010 | 07:28 PM
dsm1990gsx's Avatar
Yes it can go by several different names.
Mits2001
May 3, 2011 02:50 PM
mitsuV6
Oct 9, 2009 04:20 PM
henry75
Aug 24, 2006 03:45 PM
henry75
Aug 23, 2006 11:01 PM
bigrob069
Jul 16, 2004 09:06 PM
