99 gs Now Starts but............
Old Nov 11, 2005 | 10:09 PM
faded2's Avatar
Default 99 gs Now Starts but............
I have figured out that I can unplug the ecu and get the car to start.
But not all the time, I changed the cps and the crank sensor like you guys told
me and it still does the same thing, Ground? ECU?
Old Nov 11, 2005 | 11:03 PM
Joel_CA's Avatar
Default RE: 99 gs Now Starts but............
As you crank the engine over attempting to start it, have someone tap on the PCM casing with a screwdriver. Not to hard, just a tap. PCM failure on the 420A engines in fairly common.
Joel, CA
Old Nov 12, 2005 | 12:06 AM
slow420a's Avatar
ORIGINAL: Joel_CA
Joel, CA
x2... especially the 95 mt's.
Old Nov 12, 2005 | 02:20 AM
faded2's Avatar
I tried that and it did not work, Are the 99's just as bad as the rest of the 2g years?
Old Nov 12, 2005 | 09:22 AM
slow420a's Avatar
The best problem free year seems to be the 99 actually, they have the least amount of recalls and tbs reports, but that could be because most of them dont have as many miles on them as the 95's and such. If you know anyone with the same car, 99 gs or rs see if you can do a quick swap with their ecu and see if your car satrts with their ecu and if their car starts with yours. that will determin whether its the ecu or a different electrical probblm.
swb0510
Apr 24, 2013 10:16 PM
agarcia
Sep 17, 2012 11:48 PM
bo0st
Aug 2, 2012 06:32 PM
earthspresident
Oct 26, 2008 11:56 AM
krystalfabian
Feb 4, 2007 06:45 PM
99, ecu, gs, rs
