99 GST not starting/running
Old 09-12-2008, 03:14 PM
mazdaboi88's Avatar
Default RE: 99 GST not starting/running
i just looked up one of the pictured sensors above and i have overlooked this so often i should be ashamed of myself but i was wondering,with theMAPsensor not where it should be could that be causing my problem
  #22
Old 09-12-2008, 09:01 PM
how can a map sensor be not where it should be. It hust bolts to the top of the manifold
  #23
Old 09-12-2008, 09:54 PM
mazdaboi88's Avatar
the map sensor is not bolted down for some reason it is still wired up to car but is loose in engine bay
  #24
Old 09-14-2008, 08:58 PM
mazdaboi88's Avatar
does anyone know if a JDM motor is compatible with an american intake manifold for these vehicles or if there is a way to apply a MAP/MDP sensor to a JDM manifold because the intake manifold in the vehicle now is a JDM and has no bolt-on place for the sensor
  #25
Old 09-15-2008, 04:18 AM
silvercoupe97's Avatar
Ah, now there's some good news. You're in luck! DSMparts.com makes an MDP relocation adapter for 1G swaps in 2G cars.
http://www.dsmparts.com/customer/pro...171&page=1
Bad news is the MDP sensor checks on the EGR. Without the sensor, you'll get a CEL, but you'll still be able to turn your car on.
Pic number two is the stock fuel pressure regulator. If you have an aftermarket one, don't worry about it, just be sure to leave it plugged in (electrically).
Pic number three is the EGR control solenoids.
Here's a site that may help you locate sensor on the top of the engine.
http://members.shaw.ca/dsm.1000q/Eng...sual-index.htm
Here it is for the 1G motor.
  #26
Old 09-21-2008, 07:35 PM
yeah my mdp sensor is out, so my cel is on, and it screws with my idle. woot.
MTRaider
01-19-2014 12:21 PM
modkilla9
09-05-2008 03:41 AM
austinw23
05-02-2007 06:49 PM
kainrath
08-21-2006 06:11 PM
97GSTOR
01-05-2005 09:01 PM
Quick Reply: 99 GST not starting/running
