adjusting valves on a 1997 2.0 turbo eclipse
Old Sep 27, 2010 | 02:01 PM
ineedabin2's Avatar
Default adjusting valves on a 1997 2.0 turbo eclipse
i have a manual on cd and cant find on how to adjust the valves for my car. are they adjustable? can you send me a link on how to. Thanks
Old Sep 27, 2010 | 07:07 PM
they are not adjustable...the lifters are automatic. Why would you want to do that? you realize this is an interference motor
Old Sep 28, 2010 | 10:50 AM
ineedabin2's Avatar
Default I thought they were non adjustable and found that out ,
I did really think they were no adjustment to be made on them , I had the motor rebuit and the valves are taping like hell . I am guessing that since I had the head done the lifter springs are weaken because of the new valve ones , also I do not think they used synthetic oil soak them in and and did not fill it with it either, I am going to do this and see if that changes things , thanks for the reply ,
Old Sep 29, 2010 | 08:07 PM
new good oil will help it get quieter however the only real solution is to get the 3g revised lifter because its not the valves that are ticking it is the automatic lifters. Here is a place you can get them.
http://www.store.partsdinosaur.com/4...Adjusters.html
Old Oct 11, 2010 | 04:52 PM
ineedabin2's Avatar
what is the stock rpm set at idle , I have the 2.0 turbo , thanks
Natedogg89
May 30, 2017 03:07 AM
yahcoy
Nov 14, 2007 12:11 PM
GrayGST
Dec 11, 2006 01:21 AM
oh_what_up
Sep 6, 2006 12:13 AM
frakinstine
Nov 1, 2005 03:25 PM
