Almost done with swap. Need a little help
Old Dec 10, 2006 | 10:20 PM
  #21
paintballproam's Avatar
Default RE: Almost done with swap. Need a little help
well a green top one is coming with my motor.
Old Dec 10, 2006 | 10:53 PM
  #22
5Tizzle's Avatar
ORIGINAL: silvercoupe97
Another thing to do is move the engagement point on the pedal itself. Anytime any clutch work is done, you should have to adjust it every time....unless the point is dead on that is
Where is the adjuster for the pedal?
Old Dec 10, 2006 | 11:05 PM
  #23
silvercoupe97's Avatar
It's under the dash, if you look up from the floorboard, you'll see where the rod comes in from the engine bay and then you'll see the bracket that the rod goes through and that's where the lock nut is. The adjustment is as easy as turning the rod itself.
About 3/4 of the way down, there's some adjustment info from RRE. http://www.roadraceengineering.com/c...ywheeltech.htm
Don't forget to remove the clutch switch... http://youtube.com/watch?v=g1STI1Tw8ZI
Old Dec 11, 2006 | 08:28 PM
  #24
Nubiebubie_GSX's Avatar
Thanks Silver..
rickcjmc
Sep 26, 2014 05:54 PM
agallardo
Jan 19, 2007 06:51 PM
agallardo
Jun 20, 2006 09:30 PM
