Alrighty then
Old Nov 12, 2005 | 11:22 PM
Timmay's Avatar
Default Alrighty then
I wanna know what it takes to put a 4g63 motor in a 96 eclipse gs.
Also if i need to get a dif transmission and all that ****.
If someone know a link to a guid or something that would be even better than typing it all out.
Hope someones helpful
Old Nov 13, 2005 | 12:43 AM
slow420a's Avatar
Default RE: Alrighty then
This was talked about on numerious occasions in the past month, i am guessing that you missed it
http://forums.2g nt.com/dcboard.php?az=show_mesg&forum=4&topic_id=54176&me sg_id=54176&listing_type=search (remove the space between 2g and nt for the link to work.) This is the only swap that i have ever seen on the net. Bottom line if it was cheap and easy everyone would do it. BTW read the whole post, the project took 5 months and the guy ended up selling the car and motor seprate because it never ran right.
You will need to get a full 4g63 motor assymebly, ecu, wiring herness, fuel system, exaust, transmission, axles w/ cv joints.
You will need someone who is able to wire it all up, faberciate motor mounts, fabercate transmission mounts, and someone who is able to hook everything up, ie install.
rexbd
Jan 29, 2008 07:18 PM
eclipse27
Jul 7, 2005 12:24 AM
antomx
Sep 4, 2004 07:19 PM
Tom97rs
Nov 12, 2003 07:58 PM
