Engine cranks over then imidiatly stalls
Old Jul 5, 2005 | 11:34 PM
eclipse27's Avatar
Default Engine cranks over then imidiatly stalls
Engine cranks up, then stalls immediatly. i checked electrical connections at distributor and coil and alternator all seem'd ok. Fuel injectors are ok to. And i didn't noticed a vacum leak. Ne other suggestions?
Old Jul 6, 2005 | 08:58 AM
Default RE: Engine cranks over then imidiatly stalls
will it start? or just keep turning over?
Old Jul 6, 2005 | 03:58 PM
eclipse27's Avatar
It will start and rev to like 1 rpm...then dies. However if i give it gas awhile and keep reving it up it seems to be ok. However that doesn't work all the time. I' just got back from taking it to the mitsu dealer here, and he didn't kno wut it was. I'm thinking oxygen sensor but not sure.
Old Jul 6, 2005 | 04:54 PM
pc's Avatar
pc
When you say the Mitsu Dealer didn't know what it was, do you mean he did a hands on diagnosis and could not come up with anything, or you just asked him and he said he didn't know?
Old Jul 6, 2005 | 05:58 PM
eclipse27's Avatar
He did the "full diagnostics".....he look'd at it and used some computer thing to test it and get codes...nothing came out...tommorrow im taking it to another mitsu dealer. Im shocked have no clue wuts up with it
Old Jul 6, 2005 | 08:41 PM
very very stupid idea but my friend has a 95 TSI talon and he had a very similar problem..and for him it was only a loose\bad connection on the battery terminal..He was able to stay running by giving gas but would bogg on die if he tried to drive.
Also my 2000 GS I had did a very similar thing. The flange the the Throttle body bolts to was starting to crack and the car had a bad idle (flux. from 700RPMs 900Rpms) and would die out not long after unless I held the intake up with my hand because it would mostly seal the crack
Old Jul 6, 2005 | 10:07 PM
eclipse27's Avatar
So what do you recommnd doing. There taking my car in tommorrow to look at it. I checked my battery and put new connections on it.(there type) and the battery's fully charged.
Old Jul 7, 2005 | 12:24 AM
a Mitsu dealer should find it if its a leak. I found it the 1st time it happened, and It happened again i knew what it was and I just brought it to mitsu to have fixed cause I was to lazy to pull the intake manifold and swap it again.
do you have a turbo model or NA? and does it have an after market intake that has been on there a long time?
Mine was caused by a bad aftermarket intake, or at least the rubber 90 degree elbow off the throttle body was worped from heat over time and it was pulling down on the flange which cause it to crack and eventually fall off.
licanstik
Aug 14, 2014 04:15 PM
tl1234
Oct 27, 2010 12:52 PM
rexbd
Jan 29, 2008 07:18 PM
jrflax19
1st Generation
Feb 26, 2006 04:28 PM
