Audio help
Old Jun 21, 2006 | 05:46 PM
Nubiebubie_GSX's Avatar
Default Audio help
My stock car audio system never work since i got the car. Checked the fuse under the hood and they look good. Changed the amp and still no results. IThe stock head unit powers on, power antena goes up, and it loads and reads cds. Just no audio or even static noise. Any other help would be nice thanks.
Old Jun 21, 2006 | 06:27 PM
Default RE: Audio help
maybe the cable from the 'out' of the unit has come off or its bad.
Old Jun 21, 2006 | 08:41 PM
Ohh never thought of that. Thanks seb ill check it out.
Old Jun 22, 2006 | 11:54 AM
Its got to be the output speaker wires
Old Jun 22, 2006 | 11:59 AM
RCJr9186's Avatar
take the head unit out, check for any loose or disconnected wires/cables. if everything seems to be in order start checking the connections to the speakers themselves, if everything looks good there then you must have a problem in the wire from the unit to the speaker... get a volt meter to see if you are getting current to the end of the wire, if so then you have blown speakers. if thats the case just get urself some new 6 1/2' speakers and there you go but if it is a problem witht the wires... it's not so hard running new wires under the carpet to the rears (i did it in mine for better speaker wire connection) but running from the head unit to the door speakers is a B I A!!!!!!!! good luck hopefully you don't have to do that
2kEclipseTurbo
Jul 31, 2009 11:54 AM
Mitsuman100
Jan 10, 2007 05:11 PM
nawgee
May 1, 2006 07:22 PM
slicknick
Apr 25, 2006 10:59 PM
DvS_GsR
Aug 15, 2005 10:20 AM
