camshaft position sensor
Old Mar 22, 2007 | 12:19 AM
Dookitchen's Avatar
Default camshaft position sensor
Hey guys, I have a problem with camshaft position sensor and ignition coil problem. Last night it sputters so bad that I could not even go more then 10 mph and so I get it checked with OBDII. Ignition coil was bad and I replace it. It's lest sputtering and run much better. TOday on highway, I floored the car to test if it's really ok and it's not. I don't pick up on power after 2 second flooring the pedal and will lose power again like 10 seconds later. So I got it checked again and it's cam shaft post sensor is bad.
The question is, Do I need to set the timing or anything else to set after I put in the new cam shaft post sensor?
Also what is Secondary Air Injection Malfunction?
Thanks guys
Old Mar 22, 2007 | 12:22 AM
silvercoupe97's Avatar
Default RE: camshaft position sensor
Is your MAF still plugged in? Is your TPS still correct? We are talking 4g63, correct?
Old Mar 22, 2007 | 02:00 AM
metalmmaniac's Avatar
i had to replace both those things too and i didn't adjust anything and it runs fine now
Old Mar 22, 2007 | 11:49 AM
Dookitchen's Avatar
Oh sorry to mention that I have 420A. It's GS.
Sephiroth
Feb 25, 2018 07:46 AM
Sephiroth
Jun 4, 2006 03:03 PM
Rogo
Nov 23, 2005 03:12 PM
Jeffb1
Oct 1, 2005 04:51 PM
michael49
May 16, 2005 10:30 PM
