can we do this
[align=left]can agallardo use a razor blade to take the remains from the head gasket off of the block and head? and can he use brake cleaner to clean the surfaces on the block and head so when he puts it back together its all clean. thanks.
[/align]
[/align]
ya brake cleaner is not gonna harm the alluminum at all. nor will it leave any residue as it dissolves almost instantly. but be carefull with the razor blade like racerx55. it WILL scratch it if you touch it wrong
Best way I find to use a razor blade is to get under thick parts and pry then when it's all residue scrape the surface by DRAGGING the blade instead of pushing it... Don't know if you understand what I mean or not... But if you drag the blade against the head instead of trying to scrape it you'll NEVER put a cut in the head.
![Wink](https://mitsubishiforum.com/forum/images/smilies/wink.gif)
I gotcha man. But will dragging it really take it off? Wouldnt it just 'ride' along? If you get what i am saying... Like if there was a bump, would it not just ride over it.... I would probably have to push down harder if dragging it, right?
Stellar Force
05-05-2004 08:14 PM
