can we do this
Old Jan 6, 2007 | 06:17 PM
93eclipsegsx's Avatar
Default can we do this
[align=left]can agallardo use a razor blade to take the remains from the head gasket off of the block and head? and can he use brake cleaner to clean the surfaces on the block and head so when he puts it back together its all clean. thanks.
[/align]
Old Jan 6, 2007 | 11:56 PM
agallardo's Avatar
Default RE: can we do this
Anyone? Please help... with a cherry on top. LOL!
Old Jan 7, 2007 | 12:00 AM
paintballproam's Avatar
Im sure he CAN. I bet he could handle it.
Im just not sure if he should.
Old Jan 7, 2007 | 02:18 AM
Yeah i say he can. Anything that removes the layer of burnt crap and shows the metal will work. It provides a smooth surface and is effective.
Old Jan 7, 2007 | 07:16 AM
racerx55's Avatar
a razor blade and brake cleaner are what ive used on the hundreds of head gaskets ive changed, works great, just watch the sharp razor dont cut into the aluminum head, it does happen.
Old Jan 7, 2007 | 01:36 PM
estraw's Avatar
ya brake cleaner is not gonna harm the alluminum at all. nor will it leave any residue as it dissolves almost instantly. but be carefull with the razor blade like racerx55. it WILL scratch it if you touch it wrong
Old Jan 7, 2007 | 02:00 PM
Sanguinius's Avatar
Best way I find to use a razor blade is to get under thick parts and pry then when it's all residue scrape the surface by DRAGGING the blade instead of pushing it... Don't know if you understand what I mean or not... But if you drag the blade against the head instead of trying to scrape it you'll NEVER put a cut in the head.
Old Jan 7, 2007 | 04:22 PM
agallardo's Avatar
I gotcha man. But will dragging it really take it off? Wouldnt it just 'ride' along? If you get what i am saying... Like if there was a bump, would it not just ride over it.... I would probably have to push down harder if dragging it, right?
Old Jan 7, 2007 | 05:36 PM
estraw's Avatar
just use a gasket scraper, it looks like a chisel. you shouldnt do any damage using one of those unless you try to do some harm
Old Jan 7, 2007 | 08:44 PM
Dude dragging it will do fine. You may have to push down a little but it shouldnt be that difficult.
MzzKathee
Dec 12, 2013 07:18 AM
skewzme
Feb 5, 2009 11:06 PM
nyc95gst
Jan 13, 2007 07:34 PM
Stellar Force
May 5, 2004 08:14 PM
shane82786
Jan 7, 2004 09:44 PM
