Car start problem
Old 08-14-2006, 12:22 AM
Nubiebubie_GSX's Avatar
Default Car start problem
Well my friend has a all stock 98 gst spyder. Has under 60k miles on. He had it idling and all of a sudden he heard snap and a woosh sound and his car turned off. It would crank but not start now. Took a look at his belt and one of them the side walls was pretty ripped up, but still holding together. Any suggestion what might cause this or why his car isn't starting.
Old 08-14-2006, 12:57 AM
Default RE: Car start problem
sounds like it could be a timing slip... and maybe looking at a head rebuild. If its the timing belt the valves hitting the pistons might have been part of that sound and bent valves will cause you to crank over but not start because you cant hold compression
Old 08-14-2006, 10:49 AM
which belt are you saying is worn because like emonz said, the one you need to check is the timing belt which is covered by the plastic peice. I agree with emonz with this being the timing belt
Old 08-14-2006, 07:42 PM
well its not the belt that runs the cam gears .. but if u look from the driver side fender and align urself to where the end of the intake manifold is and just peek down, its that belt that looks torned up.
Old 08-14-2006, 07:43 PM
funny thing is its parked in a mall parking lot and the flat bed tow truck told him he wont tow his car cuz its to low.
Old 08-14-2006, 08:17 PM
93eclipsegsx's Avatar
is the air conditioning belt?
Old 08-14-2006, 09:02 PM
estraw's Avatar
ORIGINAL: 93eclipsegsx
if so, the car should still start
Old 08-14-2006, 10:51 PM
also the timing belt could have loosened up a little bit like emonz said. because it could have been that but he could be talking about another belt that looks like the problem but isnt.
Old 08-15-2006, 01:00 AM
well looks like it is probably the Alternator belt. It eventually snapped off.
Old 08-15-2006, 09:35 AM
thats would do it.
mysticrythms
03-19-2014 08:17 PM
dahoopd
11-04-2010 08:10 PM
hatchetman9449
1st Generation
08-08-2007 12:14 PM
GryphonsClaw
06-21-2006 11:33 PM
matt_75
01-26-2003 06:08 AM
Quick Reply: Car start problem
