Car start problem
Old Aug 14, 2006 | 12:22 AM
Nubiebubie_GSX's Avatar
Default Car start problem
Well my friend has a all stock 98 gst spyder. Has under 60k miles on. He had it idling and all of a sudden he heard snap and a woosh sound and his car turned off. It would crank but not start now. Took a look at his belt and one of them the side walls was pretty ripped up, but still holding together. Any suggestion what might cause this or why his car isn't starting.
Old Aug 14, 2006 | 12:57 AM
Default RE: Car start problem
sounds like it could be a timing slip... and maybe looking at a head rebuild. If its the timing belt the valves hitting the pistons might have been part of that sound and bent valves will cause you to crank over but not start because you cant hold compression
Old Aug 14, 2006 | 10:49 AM
which belt are you saying is worn because like emonz said, the one you need to check is the timing belt which is covered by the plastic peice. I agree with emonz with this being the timing belt
Old Aug 14, 2006 | 07:42 PM
well its not the belt that runs the cam gears .. but if u look from the driver side fender and align urself to where the end of the intake manifold is and just peek down, its that belt that looks torned up.
Old Aug 14, 2006 | 07:43 PM
funny thing is its parked in a mall parking lot and the flat bed tow truck told him he wont tow his car cuz its to low.
Old Aug 14, 2006 | 08:17 PM
93eclipsegsx's Avatar
is the air conditioning belt?
Old Aug 14, 2006 | 09:02 PM
estraw's Avatar
ORIGINAL: 93eclipsegsx
if so, the car should still start
Old Aug 14, 2006 | 10:51 PM
also the timing belt could have loosened up a little bit like emonz said. because it could have been that but he could be talking about another belt that looks like the problem but isnt.
Old Aug 15, 2006 | 01:00 AM
well looks like it is probably the Alternator belt. It eventually snapped off.
Old Aug 15, 2006 | 09:35 AM
thats would do it.
mysticrythms
Mar 19, 2014 08:17 PM
dahoopd
Nov 4, 2010 08:10 PM
hatchetman9449
1st Generation
Aug 8, 2007 12:14 PM
GryphonsClaw
Jun 21, 2006 11:33 PM
matt_75
Jan 26, 2003 06:08 AM
